how to test FPGA PAC N3000 network port
the cable is 12core mo3 fiber; we are purchasing X4DACBL3 to try; reset not fix;
I just found that the Image may be upgraded to Production Version for trying the connection, how can I revert it?
we bought a E40GQSFPSR optic mode to test with 12core mo3 fiber and other optic mode,seems no help.
for now,the 40G serverB is not available, i connect the netport QSFPa(QSFP+40G SR-L) to netportQSFPb(QSFP+40G SR-L) with 12core mo3 fiber
[fpga@localhost ~]$sudo fpgainfo fme
Board Management Controller, MAX10 NIOS FW version D.2.0.19
Board Management Controller, MAX10 Build version D.2.0.6
//****** FME ******//
Object Id : 0xF500000
PCIe s:b:d.f : 0000:07:00.0
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Bitstream Id : 0x23000010010309
Bitstream Version : 0.2.3
Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846
Boot Page : user
[fpga@localhost ~]$ sudo fpgainfo phy
[sudo] password for fpga:
//****** PHY ******//
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
//****** PHY GROUP 0 ******//
Direction : Line side
Speed : 10 Gbps
Number of PHYs : 8
//****** PHY GROUP 1 ******//
Direction : Host side
Speed : 10 Gbps
Number of PHYs : 8
//****** Intel C827 Retimer ******//
Port0 10G : Up
Port1 10G : Up
Port2 10G : Up
Port3 10G : Up
Port4 10G : Up
Port5 10G : Up
Port6 10G : Up
Port7 10G : Up
Retimer A Version : 101c.1064
Retimer B Version : 101c.1064
[fpga@localhost ~]$ sudo fpgainfo bmc
//****** BMC SENSORS ******//
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
( 1) Board Power : 69.56 Watts
( 2) 12V Backplane Current : 3.20 Amps
( 3) 12V Backplane Voltage : 12.15 Volts
( 4) 1.2V Voltage : 1.18 Volts
( 6) 1.8V Voltage : 1.80 Volts
( 8) 3.3V Voltage : 3.25 Volts
(10) FPGA Core Voltage : 0.90 Volts
(11) FPGA Core Current : 15.07 Amps
(12) FPGA Die Temperature : 69.00 Celsius
(13) Board Temperature : 43.50 Celsius
(14) QSFP0 Supply Voltage : 3.27 Volts
(15) QSFP0 Temperature : 51.00 Celsius
(24) 12V AUX Current : 2.53 Amps
(25) 12V AUX Voltage : 12.11 Volts
(37) QSFP1 Supply Voltage : 3.27 Volts
(38) QSFP1 Temperature : 54.00 Celsius
(44) PKVL0 Core Temperature : 68.00 Celsius
(45) PKVL0 SerDes Temperature : 68.50 Celsius
(46) PKVL1 Core Temperature : 69.00 Celsius
(47) PKVL1 SerDes Temperature : 69.50 Celsius
how to test the connection in this case ,and how to check tx and rx ?
