How to simulate a Cyclone V with USB interface?
My simulation env is ready, with working clk and reset.
How should I simulate a USB interface to this DUT?
- KennyT_altera
Are you using Qsys? If no, you can setup the DUT using nativelink.
You can look into this https://www.youtube.com/watch?v=PmVVXQchv2c
- User1588514511295925
What I have done:
on Modelsim 10.5b , build up dut bestbench, and run some testcases.
I may want to use OOP methodology.
What I like to know:
- Yes, the designers used Qsys for design. How can I use Qsys to run simulation.
- Nativelink is simple. But, I am using Modelsim do file as makefile. If I have a OOP
simulation file structure, I don'think I can use Nativelink as I may have monitor, scoreboard,
testbench, testcase, driver, etc. Am I right?
Thanks!
- KennyT_altera
Thanks, if you were using Qsys. Then you will need to use msim_setup.tcl scripts.
Here is the link to follow https://www.youtube.com/watch?v=e0X5KMVt4F8
