2 years agoHow to improve Ethernet transmission speed?
I generated some image data on the Cyclone V FPGA side, sent it to DDR3 through SGDMA, and finally sent it out from the HPS side using Ethernet. However, the sending speed is not sufficient for the ...
ZiYing_Intel
2 years agoHi,
Thanks for your reply. What I means is Intellectual property (IP).
For example Ethernet IP, embedded IP or other etc....
Also , are you using provided example design ? or this is your custom design ?
ZiYing_Intel
