13 years ago
EPCS flash problem @ DE0-Nano board
Hello ,
may be , I have posted my problem in the wrong section, sorry.
I have 2 DE0-Nano boards. One is working fine, the the other
makes problems, only when I try to flash my sof+elf design to EPC.
More details on my post here:
http://www.alteraforum.com/forum/showthread.php?t=38687
Any help is welcome.
Regards, Reinhard
    Hi Dave,
    thank you for your well-meaning advice but I do not see any necessity
    to verify this. Sorry, I have not enough time and in my view it will not
    be purposeful. Maybe you have not read it yet, but I did open another
    thread: http://www.alteraforum.com/forum/showthread.php?t=38687
    I have attached a zip-file which contains the whole project to get the
    problem reproduced and it will only take 3 min to do this. Open the project,
    load the hardware, sof or jic down to the board via Quartus programmer.
    In the folder "flash", you will find a script "myflash.sh". If you have
    have a Spansion-EPC based board it will fail but it works fine on the
    other boards. leon_heller also has verified it and a friend in germany
    also today. Problem and symtom is always the same.
    In my opinion, the DE0-Nano boards must be compatible and I hope to get
    a solution from Terasic/Altera very soon.
    Anyway , thank you very much for your effort and all the infos you have provided.
    Cheers,
    Reinhard
    --- Quote Start ---
    to verify this.
    --- Quote End ---
    No problem. Just offering an option in case you were desperate :)
    Cheers,
    Dave
    Reinhard,
    Have you tried Quartus 12.1? You could just download the standalone programmer if you don't want to download the whole thing.
    Leon
    Leon,
    I was in the opinion , you tried it on your DE0-Nano with version 12.1 already ?
    Reinhard
    Yes, but my board has the EPCS64 rather than the Spansion chip. It would be a good idea to try it with your newer boards with the Spansion chip that have the problem.
    Hallo,
    very positive news: I got a solution from terasic support.
    Here is the solution message:
    >Yes, we do replace the EPCS chip with Spansion Flash, and the steps
    >to process the EPCS programming should be a little different.
    >Before programming the EPCS via nios-2-flash-programmer, users must
    >add an EPCS patch file nios-flash-override.txt into the Nios II EDS
    >folder. The patch file is available in the folder Demonstation\EPCS_Patch
    >of DE0-Nano System CD. It needs to copy this file to the folder
    >[QuartusInstalledFolder]\nios2eds\bin (e.g. C:\altera\11.1\nios2eds\bin),
    >then execute the flash-programmer.
    The override file was only included within the last shipment, 3 days ago,
    so I have attached this file. I also have tested it and now it is working
    fine.
    many thanks to terasic support ! "The service makes the difference"
    Also thanks to all other people here provided me with a lot of infos.
    Reinhard
    Yes, due the the difference between the EPCS and Spansion Flash, there would be a littler different on process the Flash programming.
    Terasic has updated the steps with its Usermanual: before programming, there is a EPCS patch file nios-flash-override.txt added into the Nios II EDS folder,which file can be found in the online CD resource.The patch file is available in the folder Demonstation\EPCS_Patch of DE0-Nano System CD. It needs to copy this file to the folder[QuartusInstalledFolder]\nios2eds\bin > (e.g.C:\altera\11.1\nios2eds\bin), then execute the flash-programmer. Thanks.
