13 years agoEPCS flash problem @ DE0-Nano board
Hello , may be , I have posted my problem in the wrong section, sorry. I have 2 DE0-Nano boards. One is working fine, the the other makes problems, only when I try to flash my sof+elf desi...
13 years agoHallo,
very positive news: I got a solution from terasic support. Here is the solution message: >Yes, we do replace the EPCS chip with Spansion Flash, and the steps >to process the EPCS programming should be a little different. >Before programming the EPCS via nios-2-flash-programmer, users must >add an EPCS patch file nios-flash-override.txt into the Nios II EDS >folder. The patch file is available in the folder Demonstation\EPCS_Patch >of DE0-Nano System CD. It needs to copy this file to the folder >[QuartusInstalledFolder]\nios2eds\bin (e.g. C:\altera\11.1\nios2eds\bin), >then execute the flash-programmer. The override file was only included within the last shipment, 3 days ago, so I have attached this file. I also have tested it and now it is working fine. many thanks to terasic support ! "The service makes the difference" Also thanks to all other people here provided me with a lot of infos. Reinhard
