13 years agoEPCS flash problem @ DE0-Nano board
Hello , may be , I have posted my problem in the wrong section, sorry. I have 2 DE0-Nano boards. One is working fine, the the other makes problems, only when I try to flash my sof+elf desi...
13 years agoHi Dave,
thank you for your well-meaning advice but I do not see any necessity to verify this. Sorry, I have not enough time and in my view it will not be purposeful. Maybe you have not read it yet, but I did open another thread: http://www.alteraforum.com/forum/showthread.php?t=38687 I have attached a zip-file which contains the whole project to get the problem reproduced and it will only take 3 min to do this. Open the project, load the hardware, sof or jic down to the board via Quartus programmer. In the folder "flash", you will find a script "myflash.sh". If you have have a Spansion-EPC based board it will fail but it works fine on the other boards. leon_heller also has verified it and a friend in germany also today. Problem and symtom is always the same. In my opinion, the DE0-Nano boards must be compatible and I hope to get a solution from Terasic/Altera very soon. Anyway , thank you very much for your effort and all the infos you have provided. Cheers, Reinhard
