--- Quote Start ---
module project (KEY,GPIO_0);
// input [3:0] SW;
input [3:0] KEY;
output [19:0] GPIO_0;
assign GPIO_0[10] = KEY[0]; //pin 13 for KEY0 (up)
assign GPIO_0[12] = KEY[1]; //pin 15 for KEY1 (down)
assign GPIO_0[14] = KEY[2]; //pin 17 for KEY2 (left)
assign GPIO_0[16] = KEY[3]; //pin 19 for KEY3 (right)
endmodule
--- Quote End ---
--- Quote Start ---
set_global_assignment -name FAMILY "Cyclone II"
set_global_assignment -name DEVICE EP2C35F672C6
set_global_assignment -name TOP_LEVEL_ENTITY project
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 10.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "15:12:27 MARCH 09, 2011"
set_global_assignment -name LAST_QUARTUS_VERSION 10.0
set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1
set_global_assignment -name VERILOG_FILE project.v
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_global_assignment -name LL_ROOT_REGION ON -section_id "Root Region"
set_global_assignment -name LL_MEMBER_STATE LOCKED -section_id "Root Region"
set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "3.3-V LVTTL"
set_location_assignment PIN_J24 -to GPIO_0[19]
set_location_assignment PIN_J23 -to GPIO_0[18]
set_location_assignment PIN_H24 -to GPIO_0[17]
set_location_assignment PIN_H23 -to GPIO_0[16]
set_location_assignment PIN_G25 -to GPIO_0[15]
set_location_assignment PIN_K22 -to GPIO_0[14]
set_location_assignment PIN_G24 -to GPIO_0[13]
set_location_assignment PIN_G23 -to GPIO_0[12]
set_location_assignment PIN_P18 -to GPIO_0[11]
set_location_assignment PIN_N18 -to GPIO_0[10]
set_location_assignment PIN_F26 -to GPIO_0[9]
set_location_assignment PIN_F25 -to GPIO_0[8]
set_location_assignment PIN_J20 -to GPIO_0[7]
set_location_assignment PIN_J21 -to GPIO_0[6]
set_location_assignment PIN_F23 -to GPIO_0[5]
set_location_assignment PIN_F24 -to GPIO_0[4]
set_location_assignment PIN_E25 -to GPIO_0[3]
set_location_assignment PIN_E26 -to GPIO_0[2]
set_location_assignment PIN_J22 -to GPIO_0[1]
set_location_assignment PIN_D25 -to GPIO_0[0]
set_location_assignment PIN_W26 -to KEY[3]
set_location_assignment PIN_P23 -to KEY[2]
set_location_assignment PIN_N23 -to KEY[1]
set_location_assignment PIN_G26 -to KEY[0]
set_global_assignment -name MISC_FILE "C:/altera/10.0/project/project.dpf"
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
--- Quote End ---
Here you go. There are always different results when I program it into the DE2. Now that I'm home and using my PC. there's not reaction from the keys whether I press it or not, compared to previously
