18 years agoDE2 Expansion Header
:confused: Hi, I'm trying to do a parallel communication between the CycloneII of the DE2 kit and an external uC. Getting signals out of the DE2 kit on the expansion header is not a problem, b...
15 years ago --- Quote Start --- module project (KEY,GPIO_0); // input [3:0] SW; input [3:0] KEY; output [19:0] GPIO_0; assign GPIO_0[10] = KEY[0]; //pin 13 for KEY0 (up) assign GPIO_0[12] = KEY[1]; //pin 15 for KEY1 (down) assign GPIO_0[14] = KEY[2]; //pin 17 for KEY2 (left) assign GPIO_0[16] = KEY[3]; //pin 19 for KEY3 (right) endmodule --- Quote End --- --- Quote Start --- set_global_assignment -name FAMILY "Cyclone II" set_global_assignment -name DEVICE EP2C35F672C6 set_global_assignment -name TOP_LEVEL_ENTITY project set_global_assignment -name ORIGINAL_QUARTUS_VERSION 10.0 set_global_assignment -name PROJECT_CREATION_TIME_DATE "15:12:27 MARCH 09, 2011" set_global_assignment -name LAST_QUARTUS_VERSION 10.0 set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0 set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85 set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1 set_global_assignment -name VERILOG_FILE project.v set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top set_global_assignment -name LL_ROOT_REGION ON -section_id "Root Region" set_global_assignment -name LL_MEMBER_STATE LOCKED -section_id "Root Region" set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "3.3-V LVTTL" set_location_assignment PIN_J24 -to GPIO_0[19] set_location_assignment PIN_J23 -to GPIO_0[18] set_location_assignment PIN_H24 -to GPIO_0[17] set_location_assignment PIN_H23 -to GPIO_0[16] set_location_assignment PIN_G25 -to GPIO_0[15] set_location_assignment PIN_K22 -to GPIO_0[14] set_location_assignment PIN_G24 -to GPIO_0[13] set_location_assignment PIN_G23 -to GPIO_0[12] set_location_assignment PIN_P18 -to GPIO_0[11] set_location_assignment PIN_N18 -to GPIO_0[10] set_location_assignment PIN_F26 -to GPIO_0[9] set_location_assignment PIN_F25 -to GPIO_0[8] set_location_assignment PIN_J20 -to GPIO_0[7] set_location_assignment PIN_J21 -to GPIO_0[6] set_location_assignment PIN_F23 -to GPIO_0[5] set_location_assignment PIN_F24 -to GPIO_0[4] set_location_assignment PIN_E25 -to GPIO_0[3] set_location_assignment PIN_E26 -to GPIO_0[2] set_location_assignment PIN_J22 -to GPIO_0[1] set_location_assignment PIN_D25 -to GPIO_0[0] set_location_assignment PIN_W26 -to KEY[3] set_location_assignment PIN_P23 -to KEY[2] set_location_assignment PIN_N23 -to KEY[1] set_location_assignment PIN_G26 -to KEY[0] set_global_assignment -name MISC_FILE "C:/altera/10.0/project/project.dpf" set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top --- Quote End --- Here you go. There are always different results when I program it into the DE2. Now that I'm home and using my PC. there's not reaction from the keys whether I press it or not, compared to previously
