18 years agoDE2 Expansion Header
:confused: Hi, I'm trying to do a parallel communication between the CycloneII of the DE2 kit and an external uC. Getting signals out of the DE2 kit on the expansion header is not a problem, b...
15 years agoApparently there were some shortage issues on the circuit as it was too small of a space to work on >< so it's hardware issues. I wasn't too sure what happened previously when I had no shortage issue (I believe this arise because I re-solder some of the wires) and that I couldn't get the solution either.
However, since it's miraculously done, perhaps the older issue could be due to the pin assignments which I might have carelessly assigned (or perhaps seeing the wrong set of pin assignments). This is a very embarrassing mistake I've made >.< Sorry for all the trouble I made you go through :(
