Connect External Arm DSTREAM Debugger and Arm Development Studio with Intel Stratix 10 SX DK
Hi all,
I have my Intel Stratix 10 SX Development Kit up and running with FPGA design programmed into SDM QSPI flash via USB-Blaster II cable. U-Boot does run on the Cortex-A53 core when board boots up and I am able to deploy and run my hello world application on top of U-Boot on the A53 core.
I am now interested to debug my application using external Arm DSTREAM JTAG debugger by connecting to the Cortex-A53 cores and debugging it via Arm Development Studio v2022.0 . At the moment Arm DS is unable to connect to the A53 cores and gives an error that a "Stratix 10 device has not been recognized". Can someone please guide me what switch settings should I use so the A53 cores are added to the scan chain ? Please find below my current switch settings:
SW1 [1-8]: off, off, on, on, on, on, on, on
SW2 [1-4]: on, off, off, off
SW3 [1-4]: off, off, off, off
SW4 [1-4]: on, off, off, on
SW8 [1-2]: off, off
Best Regards.
- tehjingy_Altera
Hi
You could refer to the document on setting up the ARM DS.
Jingyang, Teh
- SSB
Thanks for the response. The document you mentioned above does not point on how configure the FPGA image to include the HPS into the JTAG scan chain and carry out debug via external JTAG.
Any help around that area is appreciated. At the moment, on launching a debug connection, ARM DS complains that the connected device is not recognized as a Stratix10 platform.
- tehjingy_Altera
Hi
Did you follow the steps in creating the debug configuration to the board?
https://www.intel.com/content/www/us/en/docs/programmable/683211/current/debug-the-project.html
You will need to select the Stratix10 platform.
Jingyang, Teh
- tehjingy_Altera
Hi
Any update on this case?
Jingyang, Teh
- tehjingy_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
- SSB
Hi Jingyang, Teh
Thanks a lot for the response. Essentially it seem like that the HPS JTAG is not visible to the debugger at all. This is what the SPL and U-Boot prompt looks like :
U-Boot SPL 2019.10-ga2f8989-dirty (May 13 2020 - 22:36:10 +0800) Reset state: Cold MPU 1000000 kHz L3 main 400000 kHz Main VCO 2000000 kHz Per VCO 2000000 kHz EOSC1 25000 kHz HPS MMC 50000 kHz UART 100000 kHz DDR: 4096 MiB SDRAM-ECC: Initialized success with 1105 ms QSPI: Reference clock at 400000000 Hz WDT: Not found! Trying to boot from MMC1 U-Boot 2019.10-ga2f8989-dirty (May 13 2020 - 22:36:10 +0800)socfpga_stratix10, 6 CPU: Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A53) Model: SoCFPGA Stratix 10 SoCDK DRAM: 4 GiB MMC: dwmmc0@ff808000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial0@ffc02000 Out: serial0@ffc02000 Err: serial0@ffc02000 Net: Warning: ethernet@ff800000 (eth0) using random MAC address - 9a:94:bf:47:78:41 eth0: ethernet@ff800000 Hit any key to stop autoboot: 0 SOCFPGA_STRATIX10 #
Do I need to deploy a different reference design to make HPS JTAG visible in the scan chain ? Any steps for configuring such a design ?
- SSB
Note that I am using HPS IO-48 Daughter card and using the Mictor 38 Pin connector for HPS JTAG access.
- tehjingy_Altera
Hi SSB
I see that there is a separate case that is similar that you have created.
Could we close this case and follow it up on the other case?
Jingyang, Teh
