RMoha19
7 years agoConfiguration file size for Cyclone 10LP FPGA - 10CL055YF484I7G
I am using two Cyclone 10LP FPGAs (10CL055YF484I7G). I want to know the size of configuration file so that I can select appropriate EPCQ memory
- YuanLi_S_Intel
Hi Rafi, The size is depending on the design itself. I would suggest you to create your design in Quartus and have it compiled. You can know the size from the bit stream generated. Regards, YL - DCobu
What is the largest size that you could have in the fabric of the part if you were not using external memory at all?
david
- YuanLi_S_Intel
Hi David, 119088 is the largest logic elements in Cyclone 10 LP. You may refer to Cyclone 10 LP device overview at link below for more information: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51001.pdf (Page 5) Regards, YL
