RMoha19
7 years agoConfiguration file size for Cyclone 10LP FPGA - 10CL055YF484I7G
I am using two Cyclone 10LP FPGAs (10CL055YF484I7G). I want to know the size of configuration file so that I can select appropriate EPCQ memory
YuanLi_S_Intel
7 years agoHi Rafi,
The size is depending on the design itself. I would suggest you to create your design in Quartus and have it compiled. You can know the size from the bit stream generated.
YL
