Well considered, it must work.
--- Quote Start --- who can give me the linux driver of bemicro and schematic ? thanks! --- Quote End --- I am also very interested in this, i know that linux or even win7 is not currently supported by the bemicro but will it be?. i do all my development in linux, i hate to have to install windows in a virtualbox to get the bemicro to work.. my DE2 card works like a dream in linux... - Altera_Forum
--- Quote Start --- I looked it up. A18 on a 512x16 part is the same as CE2 on the existing part. You should be able to drop in a 512x16 with no board modifications - but use the pin assigned to CE2 in the manual as A18 instead. I was looking at this part: http://www.issi.com/pdf/61-64wv51216.pdf but I believe that is part of the JEDEC spec. --- Quote End --- Hi,jshamlet. Thank you for your help! But,I didn't find any information in the manual,which pin be used assigned to A18 from the FPGA chip. pds123 - Altera_Forum
The said pin is actually named cs2 in the manual.
hi all
I'm using this thread to ask if anyone has the Bemicro schematics? all I got from Altera was some ref designs and some installation guide. if anyone found something please let me know! - Altera_Forum
I fear, it hasn't been published yet. What's the particular detail you need to know?
I'm interested in the FT2232 connections. I have the board so I can test the connections using DVM but that's awkward.
besides that, I believe that every company selling an evaluation board should supply all the information about it, if for example I'd like to use the IO connector in a Quartus project, I don't have the pin out! this is an evaluation board, not a commercial product. - Altera_Forum
I generally agree. A special point is, that BeMicro has been designed by Hitex, using a form factor they had introduced for other evaluation boards (e.g. NXP ARM) before. I don't know, if it's an Altera contract development at all.
The I/O connector mapping is completely documented in the BeMicro manual, for the FT2232 connection I have posted my findings in another thread: http://www.alteraforum.com/forum/showthread.php?t=20490 In addition, here are the FT2232 connections
The 4052 is multiplexing the FT2232 JTAG pins according to Sel A/B as follows:AD0 TCK AD1 TDI AD2 TDO AD3 TMS AD4 NCONFIG AD5 NSTATUS AD6 CONF_DONE AC0 4052 Sel A AC1 4052 Sel B
I didn't have a need to trace the FPGA I/O pins connected in Select 1 mode. Select 3 is the default mode used for JTAG configuration.0 1 2 3 TMS NC IO NC R404/TMS TDO NC IO NC R406/TDO TDI NC IO DATA R403/TDI TCK NC IO R402/DCLK R401/TCK - Altera_Forum
Hi I was wondering if anyone here that's been using their bemicro has made any use of the 80 pin edge connector? Would you know of an 80 pin connector that would slip onto the end of the bemicro from which I could run wires from? I would like to run pwr and assorted inputs to the brd through this connector and run control signals out. Thanks... Mike
--- Quote Start --- Hi I was wondering if anyone here that's been using their bemicro has made any use of the 80 pin edge connector? Would you know of an 80 pin connector that would slip onto the end of the bemicro from which I could run wires from? I would like to run pwr and assorted inputs to the brd through this connector and run control signals out. Thanks... Mike --- Quote End --- The mating connector for the card-edge on the BeMicro is the MEC6 series from Samtec: http://www.samtec.com/productinformation/technicalspecifications/overview.aspx?series=mec6-ra You can also buy a prototyping board from Hitex for the BeMicro: http://www.ehitex.de/p_info.php?products_id=311 Jake
