17 years ago
Audio CODEC AIC23 vhdl/verilog
Hello, We have a Altera EP2S60 development board (http://www.altera.com/products/devkits/altera/kit-dsp-2s60.html) , which has a Stratix II FPGA and AIC23 Audio CODEC. Altera does not have any controller or IP for controlling this audio codec. I am just wondering does any of you guys have any Verilog/VHDL example codes to control this audio codec. If you do not have then could you please direct me somewhere from where I will be able to get it. Your help would be highly appreciated. Thanks.
    Hi EOFZ,
    Is that the audio attached file can be use for cyclone III dsp development kit?
    There is also the same audio codec AIC23.
    Is that I just need to change the pin location?
    But i face some timing problem "Time requirements not met"
    Hi EOFZ,
    "Time requirement not met " is solved.
    but i face
    Critical Warning: Ignored Power-Up Level option on the following registers
    Critical Warning: Register command_gen:u_command_gen|stop_flag will power up to Low.
    How can i solve this problem? I using Cyclone III. tks.
    Your design tries to implement both asynchronous set and reset for stop_flag, which isn't provided with Cyclone III. The intended asynchronous set at power up (initial value) is ignored. Check, if you can change the initial value. If not, modify the design.
    Ok..thanks so much for your reply.
    So, if i get all the pin location correct i should get the output right?
    but i cant hear any voice.
    hai...
    when i add coefficient to the filter, the output will contain many noise.
    for example, (tap1<<4);
    What problem for this? Can any one give me some guide?
    Thanks..
    hai..
    When i add coefficient value to filter, my output contain lot of noise.
    I using shift method like(tap1>>5).
    Can any one help me or give me some guide?
    Thanks...
    Hi there
    Could you please attach NIOSII version. I am trying to roll my own, but am having problems.
    Would be much appreciated :)
    Thanks alot !
    --- Quote Start ---
    Hi, The attached is a Quartus II project for 2S60 DSP kit. The design includes Verilog codes for AIC23 audio CODEC, which digitize Line-in analog and play back to Line-out.
    The sample is fully controlled by a HDL state machine, but normally I use a Nios II controlled version and it’s much more flexible. If you love Nios II I will attach it.
    --- Quote End ---
    Any chance anyone here has the Nios II code or Qsys file? I got an AD/DA card with an AIC 23 codec on it for a DE2i-150 board and I'm trying to figure out how to send and receive data. I've been attempting to do it by bit banging but I don't think it's the right way to go...
