PJais1's avatar
PJais1
7 years ago
Arria 10: Warm Reset Error
I am designing Linux OS for our Custom board which took design reference from Arria 10 SoC.
I have designed uboot binary image by taking reference from
https://rocketboards.org/foswiki/Documentation/A10GSRDGeneratingUBootAndUBootDeviceTree
and selected QSPI flash for booting the uboot image.
After loading the uboot and peripheral rbf image in the QSPI flash card , it was observed that the HPS is not booting, their is no output on console window , also the debug uart pin is not toggled.
Also, the nRST pin which is used for warm reset becomes low after continuous intervals for around 55usec .
I am unable to understand whether this reset in generated internally by reset manager (in uboot source code ) and if so how to handle this reset so that the HPS is able to boot??
Thanks and Regards,
Priya
    • PJais1's avatar
      PJais1
      I am using Quartus 17.1 version. And for the above query which I posted, I read the manuals and did some changes in our I/O muxing. I configured Dedicated I/O bank UART as the debug UART and now console is showing output.But in the message DDR calibration is getting failed.
      The uart console is showing following Error:
      U-Boot 2014.10 (Sep 17 2019 - 15:11:16)
      CPU : Altera SOCFPGA Arria 10 Platform
      BOARD : Altera SOCFPGA Arria 10 Dev Kit
      I2C: ready
      DRAM: WARNING: Caches not enabled
      SF: Read data capture delay calibrated to 1 (0 - 2)
      SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiB
      FPGA: Early Release Succeeded.
      SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiBemif_reset interrupt acknowledged
      Error: Could Not Calibrate SDRAM
      DDRCAL: Failed
      INFO : Skip relocation as SDRAM is non secure memory
      Reserving 2048 Bytes for IRQ stack at: ffe3a6e8
      DRAM : 0 Bytes
      data abort
      pc : [<ffe001cc>] lr : [<ffe02491>]
      sp : ffe3fff0 ip : 00000016 fp : 00000001
      r10: ffd02078 r9 : ffe3aee8 r8 : ffe00000
      r7 : ffe1d3c4 r6 : 00000000 r5 : 00000000 r4 : ffeff000
      r3 : ffe3afaf r2 : ffe40000 r1 : ffe3d000 r0 : ffe3aee8
      Flags: nzcv IRQs on FIQs on Mode SVC_32
      Resetting CPU ...
      resetting ...
      Could you please help with the error?
      Priya
