Suresh430's avatar
Suresh430
5 months ago
ARM DS5 debugger Access/Detection of CM55 on Agilex5 fpga device
Hi Team,
              We recently purchased license for the ARM DS5 IDE from Altera with License file contains note as NOTICE="For use with Intel or Altera devices only". I am using Arm Development studio IDE with version 2025.1-1. ALtera Agilex 5 FPGA device configured with custom soft macro based design which is only having ARM Cortex M55 processor cores with coresight debug IP . My question is whether ARM DS IDE will detect, access and debug the Cortex M55 cores which is in the fpga through the JTAG USB Blaster ?
Please provide the detailed explanation
Suresh
    • Suresh430's avatar
      Suresh430
      Hi Team,
      We are working on Agilex 5 (Sulfur evaluation board) with a custom FPGA design that integrates:
      • ARM Cortex-M55 soft macro
      • CoreSight Debug Access Port (DAP)
      • Debug logic connected internally
      • Current connection flow is:
        Debugger (Host PC) → Altera USB Blaster → Virtual JTAG →  CoreSight DAP → Cortex-M55
        Key Clarifications Required :
        1. Virtual JTAG vs Native JTAG Access
          • Currently, the CoreSight DAP JTAG signals are routed through Virtual JTAG inside the FPGA fabric.
          • Is this architecture supported for external debuggers (ARM DS / Ashling)?
          • Can CoreSight DAP be reliably accessed via Virtual JTAG, or is this approach not recommended?
           JTAG Requirement :
      • Do we need two separate JTAG interfaces?
        • One for FPGA configuration (via USB Blaster)
        • Another dedicated ARM debug JTAG (DAP access)
      Debugger Tool Compatibility :
      Will ARM Development Studio (DS-5 / ADS) be able to:Detect Cortex-M55 through this setup?Access CoreSight components via Virtual JTAG? Or is Ashling RiscFree IDE + probe mandatory for this configuration?
      Debugger Hardware Recommendation :
      • In case Virtual JTAG is not sufficient:
        • Which debug probe/cable is recommended for Cortex-M55 debug?
          • ULINK?
          • DAPLink?
          • Ashling probe?
      • Can USB Blaster be used for CoreSight debugging, or is it limited to FPGA configuration/debug only?
      a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; }
      Reference Design / Best Practice :
      • Could you please share:
        • Any reference design or documentation showing proper integration of:
          • Cortex-M55 soft core
          • CoreSight DAP
          • JTAG/debug interface in Agilex 5 FPGA
      Suresh
      • tehjingy_Altera's avatar
        tehjingy_Altera
        Hi Suresh430
        Yes the ARM DS could be used to detect the Cortex-M55 through the jtag chain as long the ARM DS-5 supports the CoreSight SOC-600.
        The Virtual JTAG IP could not be used to debug Cortex-M55, the connection will need to go through the native Jtag connection.
        From my understanding of the Virtual Jtag IP, this IP is used as a connection for IPs in the fabric to be connected to the jtag chain.
    tehjingy_Altera
    Hi Suresh430
    For debugging the Agilex5 FPGA Devices, you could use the Ashling IDE which is Free to download.
    Below are some useful links to have a look:
    https://www.altera.com/products/development-tools/ashling
    https://altera-fpga.github.io/rel-25.3.1/demos/agilex-5/e-series/premium/riscfree-debug-linux/ug-riscfree-debug-linux-agx5e-premium/
