Björne
2 years agoWhy does aoc set ii to 6 when I use high clock frequencies?
I have a simple toy that I want to run at 1000 MHz kernel that doesn't do much: __attribute__((uses_global_work_offset(0))) __attribute__((max_global_work_dim(0))) __kernel void netsim( __global...
BoonBengT_Altera
Moderator
2 years agoHi @Björne,
Good day, just following up on the previous clarification.
By any chances did you managed to look into it?
Hope to hear from you soon.
Best Wishes
BB
- Björne2 years ago
Hi @BoonBengT_Altera , I'm using the Intel OpenCL Compiler. So the reports I'm referring to are those produced by that compiler. I'm trying to get it to make designs with 700 MHz.
