Which IP Category is recommended for the Math Square Root function?
Hi
I'm looking for assistance in creating an IP for the square root function. At the moment, I only have square root Verilog code. I'm looking for recommendations for FPGA, I/O Chip, and SDC using Quartus Prime Pro.
Thanks and best regards,
Sriram
Hi Shriram,
However, I'm having issues with timing and I/O chip placement. Any suggestions?
Timing issues had been resolved by sdc file. I reattached the file below with new sdc as I further remove the unconstraint paths. As for I/O chip placement you may have to open a new thread in FPGA, SoC, And CPLD Boards And Kits forum for better confirmations.
How to calculate / how to find speed grade around for a clock in MHz ?
The clock frequency can be checked in timing analyzer by report clock. As for speed grade you can refer to this document https://my.mouser.com/datasheet/2/612/s10_datasheet-1652682.pdf Core Performance Specifications section (page 28).
How to determine Maximum combined path delay in ns ?
Can be checked in timing analyzer as well by report timing.
Hope it helps. Thanks.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- ShengN_altera
Hi Shriram,
I have created a sdc file for the design to solve the timing requirements not met issue. The file is attached below for your reference.
These two critical warnings below can be ignored if you don't intend to use them.
Critical Warning(20615): Use the Reset Release IP in Intel Stratix 10 FPGA designs to ensure a successful configuration. For more information about the Reset Release IP, refer to the Intel Stratix 10 Configuration User Guide.
Critical Warning(19527): There are 48 unused RX channels and 48 unused TX channels in the design.
As for these five critical warnings below may be you have to open a new thread in FPGA, SoC, And CPLD Boards And Kits forum for better guidance and confirmations.
Critical Warning(12677): No exact pin location assignment(s) for 32 pins of 32 total pins. For the list of pins please refer to the I/O Assignment Warnings table in the fitter report
Critical Warning(19238): Incomplete power management settings for a VID device. As a result, the tool may not generate device bitstream.
Critical Warning(19239): Missing required setting "SDM PWRMGT SCL output"
Critical Warning(19239): Missing required setting "SDM PWRMGT SDA output"
Critical Warning(19239): Missing required setting "PMBus device 0 slave address"
Sheng
- shriram_INTL
Hi Sheng
Sorry , I don't see the attachment !! I am I missing
. sorry for the trouble. Any feedback for below question
- How to calculate / how to find speed grade around for a clock in MHz ?
- How to determine Maximum combined path delay in ns ?
best regards,
Sriram
- ShengN_altera
FPGA - Can refer https://www.intel.com/content/www/us/en/docs/programmable/683339/21-3-19-1-1/fixed-point-ips-device-family-support.html for device support list.
I/O Chip - Do you mean processor?
SDC - Do you mean Scalable Dataframe Compiler or Synopsys Design Constraints?
Sheng
- shriram_INTL
Hi Sheng
I am using Intel® Stratix® 10.
I/O Chip is the 1SG280LN2F43E1VG
SDC mean Synopsys Design Constraints
I can successfully compile the design with above attached files.
Following Critical Warning are reported
- Critical Warning(20615): Use the Reset Release IP in Intel Stratix 10 FPGA designs to ensure a successful configuration. For more information about the Reset Release IP, refer to the Intel Stratix 10 Configuration User Guide.
- Critical Warning(12677): No exact pin location assignment(s) for 34 pins of 34 total pins. For the list of pins please refer to the I/O Assignment Warnings table in the fitter report
- Critical Warning(332012): Synopsys Design Constraints File file not found: 'mlhdlc_sqrt.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
- Critical Warning(19527): There are 48 unused RX channels and 48 unused TX channels in the design.
- Critical Warning(19317): No user constrained base clocks found in the design. Calling "derive_clocks -period 1.0"
- Critical Warning(332148): Timing requirements not met
- Critical Warning(19238): Incomplete power management settings for a VID device. As a result, the tool may not generate device bitstream.
- Critical Warning(19239): Missing required setting "SDM PWRMGT SCL output"
- Critical Warning(19239): Missing required setting "SDM PWRMGT SDA output"
Timing Analysis Error
- Synopsys Design Constraints File file not found: 'mlhdlc_sqrt.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
- No user constrained base clocks found in the design. Calling "derive_clocks -period 1.0"
- Timing requirements not met
Thank you
Shriram
- ShengN_altera
Hi Shriram,
Sheng
- shriram_INTL
Hi Sheng,
Thank you so much, Sheng!!
Could you tell me your employee number or name? I'd like to seek a brief meeting for further explanation
best regards,
Sriram
