Which IP Category is recommended for the Math Square Root function?
- 4 years ago
Hi Shriram,
However, I'm having issues with timing and I/O chip placement. Any suggestions?
Timing issues had been resolved by sdc file. I reattached the file below with new sdc as I further remove the unconstraint paths. As for I/O chip placement you may have to open a new thread in FPGA, SoC, And CPLD Boards And Kits forum for better confirmations.
How to calculate / how to find speed grade around for a clock in MHz ?
The clock frequency can be checked in timing analyzer by report clock. As for speed grade you can refer to this document https://my.mouser.com/datasheet/2/612/s10_datasheet-1652682.pdf Core Performance Specifications section (page 28).
How to determine Maximum combined path delay in ns ?
Can be checked in timing analyzer as well by report timing.
Hope it helps. Thanks.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
FPGA - Can refer https://www.intel.com/content/www/us/en/docs/programmable/683339/21-3-19-1-1/fixed-point-ips-device-family-support.html for device support list.
I/O Chip - Do you mean processor?
SDC - Do you mean Scalable Dataframe Compiler or Synopsys Design Constraints?
Sheng
- shriram_INTL4 years ago
Hi Sheng
I am using Intel® Stratix® 10.
I/O Chip is the 1SG280LN2F43E1VG
SDC mean Synopsys Design Constraints
I can successfully compile the design with above attached files.
- How to calculate / how to find speed grade around for a clock in MHz ?
- How to determine Maximum combined path delay in ns ?
Following Critical Warning are reported
- Critical Warning(20615): Use the Reset Release IP in Intel Stratix 10 FPGA designs to ensure a successful configuration. For more information about the Reset Release IP, refer to the Intel Stratix 10 Configuration User Guide.
- Critical Warning(12677): No exact pin location assignment(s) for 34 pins of 34 total pins. For the list of pins please refer to the I/O Assignment Warnings table in the fitter report
- Critical Warning(332012): Synopsys Design Constraints File file not found: 'mlhdlc_sqrt.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
- Critical Warning(19527): There are 48 unused RX channels and 48 unused TX channels in the design.
- Critical Warning(19317): No user constrained base clocks found in the design. Calling "derive_clocks -period 1.0"
- Critical Warning(332148): Timing requirements not met
- Critical Warning(19238): Incomplete power management settings for a VID device. As a result, the tool may not generate device bitstream.
- Critical Warning(19239): Missing required setting "SDM PWRMGT SCL output"
- Critical Warning(19239): Missing required setting "SDM PWRMGT SDA output"
Critical Warning(19239): Missing required setting "PMBus device 0 slave address"
Timing Analysis Error
- Synopsys Design Constraints File file not found: 'mlhdlc_sqrt.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
- No user constrained base clocks found in the design. Calling "derive_clocks -period 1.0"
- Timing requirements not met
Thank you
Shriram
