Which IP Category is recommended for the Math Square Root function?
- 4 years ago
Hi Shriram,
However, I'm having issues with timing and I/O chip placement. Any suggestions?
Timing issues had been resolved by sdc file. I reattached the file below with new sdc as I further remove the unconstraint paths. As for I/O chip placement you may have to open a new thread in FPGA, SoC, And CPLD Boards And Kits forum for better confirmations.
How to calculate / how to find speed grade around for a clock in MHz ?
The clock frequency can be checked in timing analyzer by report clock. As for speed grade you can refer to this document https://my.mouser.com/datasheet/2/612/s10_datasheet-1652682.pdf Core Performance Specifications section (page 28).
How to determine Maximum combined path delay in ns ?
Can be checked in timing analyzer as well by report timing.
Hope it helps. Thanks.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Hi Sheng,
Thank you so much, Sheng!!
Could you tell me your employee number or name? I'd like to seek a brief meeting for further explanation
best regards,
Sriram
