Jia3Xu
3 years agousing HLS generated code with oneAPI in fpga
Hi, I am developing a fpga project using oneAPI, and I want to use the code which is written by intel HLS. (Migrating to oneAPI is the least thing I want to do becasue the code in HLS is huge) so ...
BoonBengT_Altera
Moderator
3 years agoHi @Jia3Xu,
Thanks for getting back with updates, yes that is valid command to generate a object files for sycl.
Coming to the second issues on the int128, unfortunately there is no direct answer for this, but based on the situation you explain and tried. Im align that possible some included library are causing the compiler to error out.
Hence possible actions here is to identify the mention library by isolating them
Hope that clarify.
Best Wishes
BB
