Jia3Xu
3 years agousing HLS generated code with oneAPI in fpga
Hi, I am developing a fpga project using oneAPI, and I want to use the code which is written by intel HLS. (Migrating to oneAPI is the least thing I want to do becasue the code in HLS is huge) so ...
BoonBengT_Altera
Moderator
3 years agoHi @Jia3Xu,
Thank you for posting in Intel community forum and hope all is well.
Just for your information creating library object you may need to specify the target to sycl as per the optimization guide:
- https://www.intel.com/content/dam/develop/external/us/en/documents/oneapi-programming-guide.pdf (page 132)
As for the error mention, it seems to be mentioning none supported int128, there are some discussion online on the targeted platform or the compiler version, hence would recommend to check on that.
-https://community.intel.com/t5/Intel-C-Compiler/128-bit-Integer-Arithmetic/m-p/962306
Hope that clarify.
Best Wishes
BB
