Remote debug AFU on-chip memory using System Console.
Hi @khyam
I am not familiar with AFU and I believe the document guide here helps to provides some guidelines on how to remote debug AFU.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/afu-developers-guide.pdf
- System Console must be started after launching the mmlink application. If System Console returns an error, close the mmlink application, re-invoke mmlink, and launch System Console again.
Richard Tan
- khyam5 years ago
Hello @RichardTanSY_Altera ,
I am able to launch and connect AFU through remote debug and I have done debugging of AFU using signal tap tool. Instead of signal tap, we can use the system console for FPGA memory debug using Avalon MM commands like master_write_32 and master_read_32. I tried using the system console tool for FPGA memory debugging, the claim command used for claiming the master service for operation(FPGA memory read/write). I got the below error for claiming master service.
error: claim_service: Could not claim service at /devices/1/(link)/TCP/sld_hub_controller_system_0_fabric.h2t_0/sld_hub/(110:132 v1 #0)/phy_0/master: Channel(s) have already been claimed, and the new claims are not compatible with the existing claims(s).
- RichardT_altera5 years ago
Hi @khyam
I am not sure what goes wrong... could you help to share your design (a simplified one .qar design file will do) that could duplicate this issue?
May I know what OS and which device that you are using?
Kindly help to provide the steps to duplicate the issue as well.
I will need to further investigate on this.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- RichardT_altera5 years ago
Hi @khyam
Could you help to share your design (a simplified one .qar design file will do) that could duplicate this issue?
Richard Tan
