Problem when programming bitstream onto A10-F100
I am trying to program a bitstream onto Mustang A10-F100 device (IEI)
Have followed the steps given in https://docs.openvinotoolkit.org/2019_R3/_docs_install_guides_VisionAcceleratorFPGA_Configure_2019R1.html=
On trying to program the device with a particular bitstream,am getting the following error-
command -
aocl program acl0 /opt/intel/openvino/bitstreams/a10_vision_design_sg1_bitstreams/2019R3_PV_PL1_FP16_SqueezeNet_VGG.aocx
Error -
How should I debug this error?
- JohnT_Altera
Could you provide the error message you observed? Could you confirm if you are using SG1 or SG2 board?
- VE000
Hi
Am using SG1 board
Error message -
aocl program: Running program from /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/linux64/libexec
FAILED to read auto-discovery string at byte 56: Expected version is 17, found 19
Error: The currently programmed/flashed design is no longer supported in this release. Please recompile the design with the present version of the SDK and re-program/flash the board.
acl_hal_mmd.c:1461:assert failure: Failed to initialize kernel interfaceprogram: acl_hal_mmd.c:1461: l_try_device: Assertion `0' failed.
aocl program: Program failed.
- JohnT_Altera
It looks like you are board flash is having older version of bitstream. You will need to reconfigure your FPGA to the latest version. Please follow the guide in https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure.html to program the flash with the latest bitstream so that after it will work on the latest OpenVINO.
- VE000
Hi
As per your suggestion I have downloaded the 2020.1 version of openvino and tried the steps as per the document provided above.
However the problem persists
Error message -
aocl program: Running program from /opt/intel/openvino/bitstreams/a10_vision_design_sg1_bitstreams/BSP/a10_1150_sg1/linux64/libexec
Programming device: a10gx_2ddr : Intel Vision Accelerator Design with Intel Arria 10 FPGA (acla10_1150_sg10)
OpenCL Notification Callback: Malformed program interface definition found in binary:
OpenCL Notification Callback: FAILED to read auto-discovery string at byte 56: Expected version is 17, found 19
OpenCL Notification Callback: Invalid binary
Failed clCreateProgramWithBinary.
Error code: -42
- JohnT_Altera
The issue is that you are not updating the FPGA flash content. Please performed the step below.
- Connect USB-Blaster to the board.
- Run "jtagconfig" to ensure that your Intel FPGA Download Cable driver is ready to use:
- Go to "/opt/intel/openvino/bitstreams/a10_vision_design_sg1_bitstreams/BSP/a10_1150_sg1/bringup"
- Program the new sof file to the board: "quartus_pgm -c 1 -m JTAG -o "p;sg1_boardtest_2ddr_base.sof""
- Soft reboot:
- Source the environment variable script you made.
- source /home/<user>/init_openvino.sh
- Run "aocl diagnose"
- Run "aocl flash acl0 sg1_boardtest_2ddr_top.aocx"
- Hard reboot the host system including powering off.
- VE000
Hi
Thank you for the reply.
I had updated the FPGA flash content also before trying to program the bitstream. Still the problem persists.
- JohnT_Altera
Do you have issue on JTAG programming? Could you provide me the step you performed before and after the CPU reboot?
