VE000
6 years agoProblem when programming bitstream onto A10-F100
I am trying to program a bitstream onto Mustang A10-F100 device (IEI) Have followed the steps given in https://docs.openvinotoolkit.org/2019_R3/_docs_install_guides_VisionAcceleratorFPGA_Configure_2...
JohnT_Altera
6 years agoHi,
Could you provide the error message you observed? Could you confirm if you are using SG1 or SG2 board?
VE000
6 years agoHi
Am using SG1 board
Error message -
aocl program: Running program from /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/linux64/libexec
FAILED to read auto-discovery string at byte 56: Expected version is 17, found 19
Error: The currently programmed/flashed design is no longer supported in this release. Please recompile the design with the present version of the SDK and re-program/flash the board.
acl_hal_mmd.c:1461:assert failure: Failed to initialize kernel interfaceprogram: acl_hal_mmd.c:1461: l_try_device: Assertion `0' failed.
aocl program: Program failed.
