Problem when programming bitstream onto A10-F100
It looks like you are board flash is having older version of bitstream. You will need to reconfigure your FPGA to the latest version. Please follow the guide in https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure.html to program the flash with the latest bitstream so that after it will work on the latest OpenVINO.
- VE0006 years ago
Hi
As per your suggestion I have downloaded the 2020.1 version of openvino and tried the steps as per the document provided above.
However the problem persists
Error message -
aocl program: Running program from /opt/intel/openvino/bitstreams/a10_vision_design_sg1_bitstreams/BSP/a10_1150_sg1/linux64/libexec
Programming device: a10gx_2ddr : Intel Vision Accelerator Design with Intel Arria 10 FPGA (acla10_1150_sg10)
OpenCL Notification Callback: Malformed program interface definition found in binary:
OpenCL Notification Callback: FAILED to read auto-discovery string at byte 56: Expected version is 17, found 19
Error: The currently programmed/flashed design is no longer supported in this release. Please recompile the design with the present version of the SDK and re-program/flash the board.
OpenCL Notification Callback: Invalid binary
Failed clCreateProgramWithBinary.
Error code: -42
aocl program: Program failed.
