Manual simulation IP authoring
Hi everyone,
I wanted to know if this is possible to simulate manually an IP created by oneAPI and to create our own testbench instead of using the testbench created in the host file. Do I need to call the module in the file kernel_sys.v generated during a make report ? Thank you !
DorianL
- aikeu
- aikeu
Hi DorianL,
Aik Eu
- whitepau_altera
Contributor
You can simulate oneAPI IP without the co simulation testbench. Please refer to the niosv code sample.
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL_FPGA/ReferenceDesigns/niosvFor smaller testbench it's also possible but you need to compile each of the files listed in the hw.tcl file.
NOTE Make sure you are using Questa FE or Questa FSE, which come with all the altera libraries pre-compiled.
