DorianL
2 years agoManual simulation IP authoring
Hi everyone, I wanted to know if this is possible to simulate manually an IP created by oneAPI and to create our own testbench instead of using the testbench created in the host file. Do I need to c...
whitepau_altera
Contributor
2 years agoYou can simulate oneAPI IP without the co simulation testbench. Please refer to the niosv code sample.
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL_FPGA/ReferenceDesigns/niosv
For smaller testbench it's also possible but you need to compile each of the files listed in the hw.tcl file.
NOTE Make sure you are using Questa FE or Questa FSE, which come with all the altera libraries pre-compiled.
