3f28dsboek
4 years agoIO stream
We noticed that there is an oneAPI FPGA example about io streaming based on D5005
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2BFPGA/Tutorials/DesignPatterns/...
- 4 years ago
Hi @3f28dsboek,
Yes there will be updates in the rollout of OFS, where by you will be allowed to modify the BSP.
Would advise if possible to engaged your local field team to get further details.
Hope that clarify.
Best Wishes
BB
BoonBengT_Altera
Moderator
4 years agoHi @3f28dsboek,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
- 3f28dsboek4 years ago
May I ask if I give up the OpenCL/DPC and turn to use RTL, should I use OPAE to take in UDP packets? If I understand correctly, UDP IP already is supported in the OPAE for PAC 5005, right?
And we can't modify OpenCL or DPC BSP for PAC D5005, right? Will the situation change when OFS stack is rolled out?
