3f28dsboek
4 years agoIO stream
We noticed that there is an oneAPI FPGA example about io streaming based on D5005
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2BFPGA/Tutorials/DesignPatterns/...
- 4 years ago
Hi @3f28dsboek,
Yes there will be updates in the rollout of OFS, where by you will be allowed to modify the BSP.
Would advise if possible to engaged your local field team to get further details.
Hope that clarify.
Best Wishes
BB
BoonBengT_Altera
Moderator
4 years agoHi @3f28dsboek,
Per my understanding modifying the for now is not possible as those are closed source.
However using custom BSP from board vendor are possible as references from here.
As for the mention supported card from bittware, please do refer to the link above under section 'Compatible FPGA Cards'. Would also recommend to get in touch with bittware to double confirm on that.
Please do let us know if we misunderstood the situation.
Best Wishes
BB
