3f28dsboek
4 years agoIO stream
We noticed that there is an oneAPI FPGA example about io streaming based on D5005
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2BFPGA/Tutorials/DesignPatterns/...
- 4 years ago
Hi @3f28dsboek,
Yes there will be updates in the rollout of OFS, where by you will be allowed to modify the BSP.
Would advise if possible to engaged your local field team to get further details.
Hope that clarify.
Best Wishes
BB
BoonBengT_Altera
Moderator
4 years agoHi @3f28dsboek,
Thank you for posting in Intel community forum and hope all is well.
For Intel card the support for the UDP offload IP are limited.
Hence would recommend to proceed with the use of OneAPI FPGA example, but would required a 3rd party card from bittware to support on the mention IP.
Please do let us know if that helps to clarify.
Best Wishes
BB
3f28dsboek
4 years agoCan you also tell me which edition of bittware card supports oneAPI with UDP IP (simply ethernet IP) ? Thank you!
