Intel HLS pipeline::lsu won't dispatch more than 8 request
Hi @AUT ,
Unfortunately at this time, without specifically modifying the generated Verilog (i.e. updating the KERNEL_SIDE_MEM_LATENCY so that the instantiated FIFO is larger), there is no way to increase the capacity of the FIFO associated with the pipelined LSU. What is the desired number of dispatch requests that you are trying to achieve?
Thank you for letting me know, we will continue with development of our Verilog based design. Given the high latency of HBM I currently need around 128 outstanding request. The best I can get even upping KERNEL_SIDE_MEM_LATENCY is 41 request so I think other more involved changes would be needed in the generated Verilog to exploit the full depth.
If possible in a future release I think a feature similar to Xilinx's num_read_outstanding would be useful especially for HBM/DDR designs.
Best,
Austin
