Paba
3 years agoIntel HLS compiler is hanging during compilation
Hi all I finally managed to get my HLS compiler working and already successfully compiled one of the example projects. So I gave it a try with my own design. First it looked good. The compiler start...
BoonBengT_Altera
Moderator
3 years agoHi @Paba,
Thank you for waiting, after some investigation with the code provided, we did notice some error from our end unfortunately there is no hang happening during the emulation flow.
We have did some try and error by removing the reference header file library which is the cause of error.
Issues are most likely on the project itself as other example are working, hence would recommend the same, perhaps to remove the some of the references library to narrow it the cause of hang.
Note: Also notice there is some missing curly braces for the first function.
Best Wishes
BB
