Intel FPGA card issue
Dear Support,
We have purchased 2 Intel FPGA card and have installed in 2 Intel server. After installing FPGA card on PCIe x16 slot one server is stucking at startup or in BIOS with error "Nmi activated - system halted".
Server Product Code : LWF2208IR848505
Server S/N : BQF900200624
FPGA Model : BD-NVV-N3000
FPGA S/N : 644C361116D0
Intel BIOS : 02.01.0011
Please suggest on above issue, does this card is faulty.
Samir Bhansali
9819986246
- JonWay_altera
Hi, if you swap it with the card on the other working server. Does it show the same problem? Please confirm if this problem follow the card or follow the server. Thanks.
- samir_bhansali
Yes i have tried with another server, but same error.
- JonWay_altera
Just to make sure...the server doesnt boot into OS with the card installed and there is no way to run lspci or any tools, right? What is the LED indication on the failing card? Blinking 1s? Always ON?
If so, once you took the card out and installed it on other server, it is seen on that server as well (which was known to work correctly). So the problem is following the card, right? And the server that was failing, once you had the card replaced, it starts working, right?
