Intel FPGA card issue
Hi, if you swap it with the card on the other working server. Does it show the same problem? Please confirm if this problem follow the card or follow the server. Thanks.
Yes i have tried with another server, but same error.
- JonWay_altera6 years ago
Just to make sure...the server doesnt boot into OS with the card installed and there is no way to run lspci or any tools, right? What is the LED indication on the failing card? Blinking 1s? Always ON?
If so, once you took the card out and installed it on other server, it is seen on that server as well (which was known to work correctly). So the problem is following the card, right? And the server that was failing, once you had the card replaced, it starts working, right?
- samir_bhansali6 years ago
Led is always on and issue might be with card. I have demanded replacement from Intel.
Hi, I have sent you a private message.
