samir_bhansali
6 years agoIntel FPGA card issue
Dear Support,
We have purchased 2 Intel FPGA card and have installed in 2 Intel server. After installing FPGA card on PCIe x16 slot one server is stucking at startup or in BIOS with error "Nmi acti...
samir_bhansali
6 years agoHi,
Yes i have tried with another server, but same error.
JonWay_altera
6 years agoJust to make sure...the server doesnt boot into OS with the card installed and there is no way to run lspci or any tools, right? What is the LED indication on the failing card? Blinking 1s? Always ON?
If so, once you took the card out and installed it on other server, it is seen on that server as well (which was known to work correctly). So the problem is following the card, right? And the server that was failing, once you had the card replaced, it starts working, right?
- samir_bhansali6 years ago
Led is always on and issue might be with card. I have demanded replacement from Intel.
- JonWay_altera6 years ago
Hi, I have sent you a private message.
I have not received any message, can you please help to replace FPGA card asap.
