Facing "Error: Failed to synthesize partition" followed by Partial Reconfiguration errors while generating GBS file
I'm trying to generate a GBS file for my custom AFU using "$OPAE_PLATFORM_ROOT/bin/run.sh" once build_synth folder is created by "afu_synth_setup --source hw/rtl/filelist.txt build_synth".
After some time of the run, I'm ending up with Partition and Partial Reconfiguration errors.
I'm attaching a document consisting of a series of messages before the failure of GBS generation occurs.
Few error messages from the document are as follows,
Error (23031): Evaluation of Tcl script ./a10_partial_reconfig/flow.tcl unsuccessful
Technical Details:
Software: Quartus Prime Pro 17.1.1
FPGA : Intel Arria X (10AX115N2F40E2LG)
Target Card: PAC with Intel Arria X GX FPGA
Acceleration Stack : Version 1.2
Operting System:
NAME="CentOS Linux"
VERSION="7 (Core)"
Any suggestions on this will be helpful.
Thank you
- RichardT_altera
Could you try running the example below and see does it works?
- UTech
I have tried to run the example in the above link, but I ended up with an error "Error enumerating FPGAs: no driver available" when I ran the following command from the document,
sudo fpgaconf $OPAE_PLATFORM_ROOT/hw/samples/nlb_mode_0/bin/\ nlb_mode_0.gbs
I searched for the error message and came across the following link(also please find the attachment for the screenshot),
"https://www.intel.com/content/www/us/en/programmable/documentation/iyu1522005567196.html"
Do I need to install any drivers or require hardware for generating GBS?
- RichardT_altera
>> No need.
Please ignore my previous message.
Could you run the Minimal Flow Example from the link below, to generate the .gbs file?
If can't generate, you might need to check the environment setup.
Otherwise, could be design related issue.
- RichardT_altera
It seems that the file name output_files/afu_fit/green_region.pmsf does not exist or can't be read. Make sure the file path and file name are correct, that the file is readable (check permissions), and enter the file name again.
- User1582192733150209
ONE POSSBIEL REASON MIGHT BE the licenses bundled in Acceleration Stack are expired,YOU NEED TO EXTEND IT BY DOWNLOAD AND INSTALL A PATCH AS BELOW
https://www.intel.com/content/www/us/en/search.html?ws=text#q=acceleration%20stack%20patch&t=All
JIM
