UTech
6 years agoFacing "Error: Failed to synthesize partition" followed by Partial Reconfiguration errors while generating GBS file
Hi, I'm trying to generate a GBS file for my custom AFU using "$OPAE_PLATFORM_ROOT/bin/run.sh" once build_synth folder is created by "afu_synth_setup --source hw/rtl/filelist.txt build_synth". Afte...
RichardT_altera
6 years agoHi,
It seems that the file name output_files/afu_fit/green_region.pmsf does not exist or can't be read. Make sure the file path and file name are correct, that the file is readable (check permissions), and enter the file name again.
