DSP Double Pumping
Following an old question (https://forums.intel.com/s/question/0D50P00004MInzpSAD/double-pumping-dsp-units-ip) is there any way to allow double pumping of DSPs in Stratix 10 and to exploit this directly in OpenCL?
- HRZ
The OpenCL compiler does not support DSP double-pumping and in fact, even Block RAM double-pumping that was supported for older FPGAs (Stratix V and Arria 10) has been disabled for Stratix 10. Even though this would be a very useful feature since kernels on Stratix 10 tend to run at far lower frequencies than the promised 800-900 MHz, seeing how even the existing Block RAM double-pumping was disabled for Stratix 10, I would not expect DSP double-pumping to ever be supported. The option to implement DSP double-pumping manually in RTL and using it as an RTL blackbox in OpenCL theoretically exists, but it won't be easy to implement and I am not sure if the OpenCL compiler provides a 2x clock on Stratix 10 anymore (or at all).
- KennyT_altera
Let me get engineering to look into this for S10. Since feature can increase the Fmax.
- KennyT_altera
Double pumping does work on S10. You can apply the attribute doublepump to request double pumping for a given array. Will request to have it on dsp for the future. Thanks
- tde_m
Thanks!
In your opinion, would it be possible to implement it as RTL block? Does OpenCL compiler/designs provide everything that I would need for that?
I could not find any useful documentation for this.
- HRZ
@KennyT_Intel This is not true, Section 10.3 of the documentation (https://www.intel.com/content/www/us/en/programmable/documentation/mwh1391807516407.html#jhl1520273455239) clearly states that no 2x clock is provided in the design by the compiler for Stratix 10 and hence, Block RAM double-pumping is not available on Stratix 10. This also means that any type of double-pumping cannot be implemented by the user in RTL either since there is no 2x clock in the system generated by the compiler.
- KennyT_altera
Thanks for pointing out, the attribute doublepump for Startix 10 should be working. The compiler may not infer double-pumping my default, but the attribute should always be able to override that.
Will have this documentation corrected.
- KennyT_altera
You can refer to https://www.intel.com/content/www/us/en/programmable/documentation/mwh1391807516407.html#chn1469549457114__section_or3_mk2_5w -> Double Pumping
You will find an example there.
- tde_m
Thanks, but my question was related to DSP Double Pumping, not to BRAM Double Pumping. The Intel documentation mention only the latter.
- KennyT_altera
As of now, we do not have DSP double pumping, I had make a request for the engineering to have it in the future. Thanks
