tde_m
6 years agoDSP Double Pumping
Following an old question (https://forums.intel.com/s/question/0D50P00004MInzpSAD/double-pumping-dsp-units-ip) is there any way to allow double pumping of DSPs in Stratix 10 and to exploit this direc...
HRZ
6 years ago@KennyT_Intel This is not true, Section 10.3 of the documentation (https://www.intel.com/content/www/us/en/programmable/documentation/mwh1391807516407.html#jhl1520273455239) clearly states that no 2x clock is provided in the design by the compiler for Stratix 10 and hence, Block RAM double-pumping is not available on Stratix 10. This also means that any type of double-pumping cannot be implemented by the user in RTL either since there is no 2x clock in the system generated by the compiler.
KennyT_altera
6 years agoThanks for pointing out, the attribute doublepump for Startix 10 should be working. The compiler may not infer double-pumping my default, but the attribute should always be able to override that.
Will have this documentation corrected.
