DSP Double Pumping
Double pumping does work on S10. You can apply the attribute doublepump to request double pumping for a given array. Will request to have it on dsp for the future. Thanks
- tde_m6 years ago
Thanks!
In your opinion, would it be possible to implement it as RTL block? Does OpenCL compiler/designs provide everything that I would need for that?
I could not find any useful documentation for this.
- HRZ6 years ago
@KennyT_Intel This is not true, Section 10.3 of the documentation (https://www.intel.com/content/www/us/en/programmable/documentation/mwh1391807516407.html#jhl1520273455239) clearly states that no 2x clock is provided in the design by the compiler for Stratix 10 and hence, Block RAM double-pumping is not available on Stratix 10. This also means that any type of double-pumping cannot be implemented by the user in RTL either since there is no 2x clock in the system generated by the compiler.
- KennyT_altera6 years ago
Thanks for pointing out, the attribute doublepump for Startix 10 should be working. The compiler may not infer double-pumping my default, but the attribute should always be able to override that.
Will have this documentation corrected.
- HRZ6 years ago
Interesting; I just tested Block RAM double-pumping on Stratix 10 and indeed it seems to work. All this time I was thinking it won't work because the documentation said so. Having DSP double-pumping on top of that will be extremely valuable and a huge advantage over the main competitor's HLS compiler (among numerous other advantages that Intel's HLS compiler has). In fact, on Stratix 10 there is probably room to even do triple-pumping, considering how high the peak operating frequency of the Block RAMs and the DSPs is compared to typical kernel frequency.
