Knowledge Base Article
Why o_rx_pcs_fully_aligned does not assert for 40GE-4 Advanced mode F-Tile Ethernet Hard IP design when Custom Ethernet line rate > 63Gbps?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3 and earlier, you might observe o_rx_pcs_fully_aligned does not assert for the F-Tile Ethernet Hard IP design with below configurations:
  • Advanced mode: Enabled
  • Ethernet mode: 40GE-4
  • Custom Ethernet line rate: > 63 Gbps
Resolution
There is no workaround. There is no fix planned in the future.
When advanced mode enabled for 40GE-4 design, supported custom Ethernet line rate is: 41.25~63 Gbps.
Updated 3 months ago
Version 3.0
