Knowledge Base Article
Why is there a Verilog HDL warning that delay control is not supported for synthesis when using the Intel FPGA MII to RMII Converter Core?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1.1, the following Verilog HDL warnings might appear during synthesis when a design includes the MII to RMII Converter Core IP:
Warning: Verilog HDL warning at intel_fpga_mii2rmii.sv(344): delay control is not supported for synthesis
Warning: Verilog HDL warning at intel_fpga_mii2rmii.sv(345): delay control is not supported for synthesis
The warnings are caused by zero-delay controls in the IP HDL. Quartus® synthesis ignores these delay controls, and there is no functional impact on the compiled design.
Resolution
You may safely ignore these warnings. There is no functional impact.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 27.1.
Updated 10 hours ago
