Knowledge Base Article
Why is the SD-SDI rx_dataout incorrect when using software versions 12.1sp1 and later?
Description
Due to a problem in Quartus® II software version 12.1sp1 and later, you may see the rx_dataout recovered incorrectly when receiving SD-SDI with a high jitter source. Both SDI® and SDI II IP Cores are affected.Resolution
To work around this problem when using software version 15.0 of the SDI II IP Core, download and install patch 0.19 from the links below.
- Download the version 15.0 patch 0.19 for Windows (.exe)
- Download the version 15.0 patch 0.19 for Linux (.run)
- Download the Readme for the Quartus II software version 15.0 patch 0.19 (.txt)
The jitter tolerance for SDI and SDI II IP Cores is scheduled to be improved in a future release of the Quartus II software.
Updated 10 months ago
