Knowledge Base Article
Why is the interrupt signal on 16550 Compatible UART Intel® FPGA IP asserted right after reset releases?
Description
Due to a problem with Intel® Quartus® Prime Standard Edition Software version 21.1 and 21.1.1,  ier_dlh Interrupt signals on 16550 Compatible UART Intel® FPGA IP are asserted right after reset releases.
Resolution
To work around this problem, there are two options:
1. Use Intel® Quartus® Prime Standard Edition Software version 22.1 or later versions because the problem has been fixed in Intel® Quartus® Prime Standard Edition Software version 22.1.
2. Read rbr_thr_dll register, then the interrupt signal will be cleared.
Updated 1 month ago
Version 2.0
