Knowledge Base Article
Why is the eCPRI FPGA IP unable to run on hardware using Stratix® 10 E-Tile with the Nios® V Processor for FPGA and turn on the interworking function (IWF)?
Description
Due to a problem in the eCPRI FPGA IP version 3.0.2 in the example design, you may find that there is an error shown at the 10G transaction after changing the dynamic reconfiguration process from 25G to 10G.
Resolution
There is currently no plan to fix this behavior in a future Quartus® Prime release.
Updated 4 months ago
Version 6.0
