Knowledge Base Article
Why is the bus ordering reversed in the Technology Map Viewer?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 or earlier, you might see that the bus ordering is reversed in the Technology Map Viewer. This problem occurs when a design contains a Block Design File (BDF) whose output bus is connected to a SystemVerilog HDL packed array from a top-level SystemVerilog HDL module.
For example, the expected mapping in the Technology Map Viewer is:
  • inst0 -> Out[0]
  • inst1 -> Out[1]
  • inst2 -> Out[2]
  • inst3 -> Out[3]
However, the actual mapping after compilation in the Technology Map Viewer become:
  • inst0 -> Out[3]
  • inst1 -> Out[2]
  • inst2 -> Out[1]
  • inst3 -> Out[0]
Resolution
To work around this problem, do one of the following:
  • Convert the BDF file to Verilog HDL or VHDL.
    • Open the BDF file in the Quartus® Prime Standard Edition Software.
    • Select File > Create / Update > Create HDL Design File from Current File.
    • Choose Verilog HDL or VHDL.
    • Replace the original BDF module in the Quartus® Prime Pro Edition Software project with the generated HDL file.
  • Explicitly reorder the bits in the top-level SystemVerilog HDL module by using a SystemVerilog HDL streaming operator in the port connection.
Updated 1 month ago
Version 2.0
