Knowledge Base Article
Why does the Simulation Library Compiler fail due to a missing km_220model.sv file in Quartus® Prime Pro Edition 26.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1, the Simulation Library Compiler might fail when compiling simulation libraries for a supported third-party simulator (for example Aldec Riviera-PRO*, Siemens EDA QuestaSim*, or Cadence Xcelium*) if you compile libraries using RTL-only or Compatible Mode for Quartus simulation flow without selecting a specific device family.
The compile might stop with an error that a simulation source file such as km_220model.sv cannot be found under the Quartus installation quartus/eda/sim_lib directory.
Example errors:
Cannot find source file: <Quartus installation>/quartus/eda/sim_lib/km_220model.sv
Failed to open design unit file km_220model.sv in read mode.
This occurs because the Simulation Library Compiler requests certain simulation model files that are not included in the Quartus® Prime Pro Edition software version 26.1 installer. Those model files are not required to simulate designs that target currently supported device families. Libraries that already compiled successfully before the error remain valid.
Refer to the Quartus Prime Pro Edition User Guide: Third-party Simulation (document ID: 683870).
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 26.1, follow these steps:
  1. Open a command prompt or terminal where the Quartus Prime software and your simulator license are available.
  2. Re-run the Simulation Library Compiler and specify your target device family with the -family option. Do not use an RTL-only compile that omits -family when you only need libraries for one device family.
Example (Aldec Riviera-PRO, Verilog, Quartus-compatible mode):
quartus_sh --simlib_comp -tool rivierapro -language verilog -mode quartus -family "Arria 10" -tool_path <path_to_riviera_bin> -directory <output_directory>
Replace Arria® 10 FPGA with your device family name. Run quartus_sh --help=simlib_comp to list valid -family values for your install.
Alternatively, in the Quartus Prime software GUI:
  1. Click Tools > Launch Simulation Library Compiler.
  2. Select your simulation tool, HDL language, target device family, and output location.
  3. Start Compilation.
If you must keep an RTL-only or all-library compile on version 26.1 only:
  1. Create an empty placeholder file named km_220model.sv in <Quartus installation>/quartus/eda/sim_lib/.
  2. Re-run the Simulation Library Compiler.
  3. If the compile reports another missing file under sim_lib with a similar name pattern, create an empty placeholder for that file and continue.
This problem is fixed in the Quartus® Prime Pro Edition Software version 26.3.
Updated 3 months ago
Version 3.0
