Knowledge Base Article
Why does the o_rx_pcs_ready signal fail to assert in hardware for the PAM4 variant of the F-Tile Ethernet FPGA Hard IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3 and earlier, the o_rx_pcs_ready signal will fail to assert in hardware for the PAM4 variant of the F-Tile Ethernet FPGA Hard IP when the variant is using both a 312.5MHz PMA reference clock and the Quartus Setting File(QSF) assignment VSR_MODE_LOW_LOSS is being used.
Resolution
To work around this problem, disable the QSF assignment VSR_MODE_LOW_LOSS.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 23.4.
Updated 5 months ago
Version 4.0
