Knowledge Base Article
Why does the "Nios® V Command Shell (Quartus® Prime 24.1std)" not work on Windows?
Description
Due to the problem of Quartus® Prime Standard Edition Software version 24.1, the path of a shortcut in the Nios® V Command Shell is incorrect.
Resolution
  1. Search "Nios V Command Shell (Quartus Prime 24.1std)" in Windows Search Box.
  2. Right-click and select "Open file location."
  3. Right-click on "Nios V Command Shell (Quartus Prime 24.1std)", and select Properties
  4. Replace "C:\niosv\bin\niosv-shell.exe" in Target with "C:\altera\24.1std\niosv\bin\niosv-shell.exe" when the install path is default.
Additional Information
This problem will be fixed in future release of Quartus® Prime Standard Edition Software.
Updated 3 months ago
Version 2.0
